Mask through multiple video tracks?
George Dean replied 8 years, 2 months ago 4 Members · 20 Replies
George Dean
June 25, 2018 at 10:08 pmJohn, go back to your first illustration. I think what Joe wants is what you have there, the duck and water visible through the port hole, with your other animation of the arrow and ball in front of the main (background), but when the ball crosses the port hole the ball should go behind the port hole and not be seen, only seen on the background layer.
So the order would be blue background layer, ball and arrow animation overlaying the background (middle layer), port hole animation overlaying everything else (would be the top layer)
At least that is what I get from his explanation. Sure hope I haven’t made it more confusing!! maybe I should have stayed out of it.
Best Regards……George
John Bolton
June 26, 2018 at 7:28 amAh OK George.. Yes… I guess you are correct….. hopefully.
Will gave a play…..
John Bolton
June 26, 2018 at 9:05 amHad a think and a quick play
Do you think it is meant to be like this.
https://www.youtube.com/watch?v=biwXaZN51wAMust be getting close now 🙂
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
John Bolton
June 27, 2018 at 6:42 pmHere is another version where the Main Image items go behind the Masked Hole Item
https://www.youtube.com/watch?v=gohk478AidMIf it is not this then… Who knows… ☺
Regards
George Dean
June 27, 2018 at 7:22 pmBy John Bolton:
“Had a think and a quick playDo you think it is meant to be like this.
Must be getting close now :)”
That is what I think he means/wants, but apparently he got hung up on something and can’t reply yet.
I surely think John you have covered just about all the possible combination of guesses there are, great job.
John Bolton
June 28, 2018 at 4:44 pmHi George and Graham or anyone else that knows the answer
I notice that sometimes where I add the CODE for the HTTPS link ( after highlighting the link and then pressing CODE ) it just show the link but on one of the links it shows YouTube embed?
Any clues and I have searched but found not solution
George Dean
June 28, 2018 at 5:11 pmI don’t have the specific answer, but if you just copy the youtube URL and then paste it directly in your post, it should embed.
Best Regards…..George
John Bolton
June 28, 2018 at 8:09 pmI did try that but it does not show in the preview.. Maybe it can’t so I try as a test..
If it fails…then NP////https://www.youtube.com/watch?v=gohk478AidM
Test to see if this embed the video
George Dean
June 28, 2018 at 11:17 pmThat has tripped me up more than once, by error trying to use the ‘link’, and I guess I’m not doing it correctly either, or have forgotten how to, so just paste direct. Glad it is working for you now.
