Activity Forums Adobe After Effects Mask / shape tracking with individual points
  • Mask / shape tracking with individual points
    Posted by Kurisuta Vd wilk on January 24, 2012 at 3:58 pm
    Hello all!
    This is my setup with three shapes:
    square – line – square
    The squares are scaling individualy to audio with keyframes.
    What i want is : The line on its leftside to follow the left square + rightside of the line follow the right square.
    So animate the line on two different points.
    Any Tips? Im lost.
    Greetings Krista
    Kurisuta Vd wilk replied 14 years, 7 months ago 2 Members · 2 Replies
  • John Cuevas
    January 24, 2012 at 4:18 pm
    Not sure how you made your line, but try using the “Generate > Beam” effect. It easily allows you to control the end points of a line. You could use some simple expression to attach them to your boxes.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Kurisuta Vd wilk
    January 24, 2012 at 4:48 pm
    In this case it is a perfect solution !! Someone else pointed out to use Corner Pin for the Squares. and i think that will be perfect !!! Thanks very much !!
    No knowledge is a Statement
