Activity Forums Adobe After Effects Mask Selection Issue
  • Mask Selection Issue
    Posted by Brian Murray on June 28, 2011 at 8:58 pm
    I have about 5 years of professional experience with AE and I’ve never had this problem before. Normally when you want to click and drag to grab a selection of points in a mask, you select one point and then proceed to drag a marquee around your desired points. Out of nowhere today, AE stopped functioning like this for me. Now when I try to click off of the mask it doesn’t deselect. When I click and drag somewhere completely away from the mask it drags the point points nearest to my cursor. when I double click away from the mask it still send the mask into “transform mode”. I’m wondering if I may have accidentally hit a hot key that change the mask editing mode or auto select mode.
    I posted a screen capture video of the problem. Thanks for your help.
    https://screencast.com/t/LwOte3G6Opr5
    Alex Dobre replied 13 years, 1 month ago 2 Members · 1 Reply
  • Alex Dobre
    July 11, 2013 at 1:16 am
    Had the same problem. Make another mask on a different layer, it should act normal afterwords.
