Activity Forums Adobe After Effects Mask Selection Issue
  • Mask Selection Issue
    Posted by Brian Murray on June 28, 2011 at 9:00 pm
    I have about 5 years of professional experience with AE and I’ve never had this problem before. Normally when you want to click and drag to grab a selection of points in a mask, you select one point and then proceed to drag a marquee around your desired points. Out of nowhere today, AE stopped functioning like this for me. Now when I try to click off of the mask it doesn’t deselect. When I click and drag somewhere completely away from the mask it drags the point points nearest to my cursor. when I double click away from the mask it still send the mask into “transform mode”. I’m wondering if I may have accidentally hit a hot key that change the mask editing mode or auto select mode.
    I posted a screen capture video of the problem. Thanks for your help.
    https://screencast.com/t/LwOte3G6Opr5
    Brian Murray replied 15 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
