Activity Forums Adobe After Effects mask properties change in 3d
  • mask properties change in 3d
    Posted by Tom Edwards on April 30, 2013 at 4:21 pm
    this is probably an operator error (it generally is).
    i have a couple words of text that i want to slide onto a page.
    so i have a text layer
    i place a mask over it and keyframe the mask path and position where i want it to end.
    i pull the text slightly off to the left then collapse the mask to hide the text — keyframe both.
    render and viola — text animates in.
    however, if i make the layer 3D, the text still animates in but the collapsed mask no longer hides the text. i can see the mask moving — it’s just not hiding the text like a good mask should.
    i tried a couple of different animate on techniques using a mask path — but noticed all of the masked animation properties disappear as soon as i make the layer 3d.
    so now i’m just puzzled.
    thoughts?
    using ae cs6 11.0.2
    Tom Edwards replied 13 years, 4 months ago 2 Members · 2 Replies
  • John Cuevas
    April 30, 2013 at 4:55 pm
    Sounds like you are using the Ray-traced 3D renderer, do you need ray-tracing for this project, which will cause the issues you describing. Press Cntl+K to open your comp dialogue and change the render to Classic 3D
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Tom Edwards
    April 30, 2013 at 5:07 pm
    ray trace is on. thank you very much. great;y appreciated.
