Activity › Forums › Adobe After Effects › Mask position expression Help
Posted by Eric Goldstein on September 16, 2009 at 11:06 pmHi,
I want to use an expression to globally change all mask path positions in the x and y across a series of key frames. Any help would be appreciated.
Eric
Eric Goldstein
Giraffe Film Company
Los Angeles
eric@giraffefilm.comEric Goldstein replied 16 years, 11 months ago 2 Members · 3 Replies -
Eric Goldstein
September 16, 2009 at 11:27 pmHi, I tried this:
The manual says that expressions can’t be used directly to affect a mask path, but that mask path can be linked to other properties to affect it. So, I made a layer called Mask Repo 1 and pickwhipped the mask path of mask 1 to the position property of layer: Mask Repo 1. I was hoping then “to change the position on Mask Repo 1 to globally reposition the keyframes of Mask Path 1. But, I get an error message, which says: AE warning: “Object of type 1024 found wheer a Property is needed.”
This is the expression produced by pickwhipping the position property of Mask Repo 1: “thisComp.layer(“Mask Repo 1″).transform.position[0]”
Any thoughts?
Eric
thisComp.layer(“Mask Repo 1”).transform.position[0]
Eric Goldstein
Los Angeles
eric@giraffefilm.com -
Adriano Moraes
September 16, 2009 at 11:58 pmHi Eric!
Try some of those:
https://aescripts.com/tracker2mask/
Those are the things that came to my mind when I read your post.
Those are scripts not straight expressions but they can do what some expressions can´t.
Hope it was of some help.
Cheers.
adriano ninguem.
Eric Goldstein
September 17, 2009 at 1:39 amHi Adriano,
Thanks very much for your suggestions. Along with mask automation script, there was another that allowed the global key frame changes I was looking for. Between the two of them it’s going to really speed up my masking.
Thanks again,
Eric
Eric Goldstein
Los Angeles
