Activity Forums Adobe After Effects mask not tracking properly on flipping coin comp
  • mask not tracking properly on flipping coin comp
    Posted by Raine Parrish on February 9, 2006 at 9:54 pm
    hello,
    I’ve created a composition of a coin flipping thru the air- towards camera- then falling away. In order to create the illusion of depth- I’ve created a striped solid- which I am masking, frame by frame, creating the edge of the coin as it moves thru the air and flips.
    Two things have gone wrong-
    1. As the coin flips on it’s axis- the writing on the coin is reversed- something I can live with for now- but I would ultimately like to fix this.
    2. More importantly- for some reason- in my comp window the masking is tracking perfectly- but upon rendering- the mask is lagging- and mis-shaped.
    I’m completely stumped.
    Using 6.5 pro on PC.
    Thanks in adance.
    rp
    Raine Parrish replied 20 years, 7 months ago 2 Members · 5 Replies
  • John Dickinson
    February 9, 2006 at 10:28 pm
    are you rendering to fields?
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Raine Parrish
    February 9, 2006 at 10:48 pm
    Thank you for quick reply.
    Rendering to fields? I’m sorry- I don’t know about that- I usually just go thru and click off the quality, compression stuff- where do I find that?
  • Raine Parrish
    February 9, 2006 at 10:53 pm
    I see in the render que- for fields- upper lower or none- I just tried all of them – no difference. I usually have it default to none.
    And BTW- I have taken a still of the coin (JPEG) and that’s what I am animating.
  • John Dickinson
    February 9, 2006 at 10:54 pm
    fields rendering is located in the Render Settings section of the Render Queue window. If you don’t know what they are it’s probably not the problem. Can you email me the file and I can take a look.
    john@motionworks.com.au
    JD
    John Dickinson
    Motionworks
  • Raine Parrish
    February 9, 2006 at 11:13 pm
    yep- should get it in a moment, and thank you.
