Activity Forums Adobe After Effects Mask not fully filling in problem
  • Mask not fully filling in problem
    Posted by Alan Lecter on May 15, 2014 at 10:34 pm
    I created a mask for a standard lightsaber effect. I spent the time adjusting the points of the mask as the lightsaber moved around the screen. For speed, I didn’t have it filled in as I performed the task. Upon finishing and playing the movie, all looks good until about half-way through the mask doesn’t fill in. See attached image.
    What have I done and can I fix? Moving the mask or adjusting the vertices affects every previous frame requiring me to adjust the points of the mask again starting at frame 1 (arrgggh!). All suggestions welcome. Thanks in advance. (AE CS6 on Win7)
    Darby Edelen replied 12 years, 3 months ago 2 Members · 3 Replies
  • Darby Edelen
    May 16, 2014 at 4:14 am
    It looks like your mask goes beyond the edge of the layer it’s applied to.
    If that’s the case then there are a couple of possible solutions. One is to use the pan behind tool to move the layer without changing the position of the mask. The other is to apply a fill effect and set the fill mask property to the mask in question (or check all masks if that works for your purpose).
    Darby Edelen
  • Alan Lecter
    May 16, 2014 at 7:58 am
    Darby – thanks for the suggestions. I’ll check out which solution is easier.
    Earlier, in the keyframing process, the lightsaber extended offscreen and I extended the mask offscreen according. See image. Is this a newbie mistake? Should I only mask to edge of screen to prevent this from occuring.
  • Darby Edelen
    May 17, 2014 at 3:35 am
    Masking outside of the frame is no problem.
    It’s not uncommon to move masks outside of the composition boundaries when they are no longer needed.
    I think your issue is only related to the size or position of the layer that you are masking. You want the layer to fill the composition.
    Darby Edelen
