Activity › Forums › Adobe After Effects › Mask not aligning with path
  • Mask not aligning with path
    Posted by Conal Clapper on August 22, 2013 at 11:45 pm
    1) I used rotobrush to rotoscope a short section of a video clip.
    2) I used Auto-trace to convert this rotoscope into a mask.
    3) When I paste the mask to my new layer the mask does not match up with the path, as in the picture below.
    This is probably a mistake on my part, but I would like to get it fixed either way.
    Thanks in advance.
    Conal Clapper replied 13 years, 1 month ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    August 25, 2013 at 8:04 pm
    Ensure that ALL layers have identical pixel dimensions and pixel aspect ratio.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Conal Clapper
    September 1, 2013 at 8:13 pm
    The two layers are exact replicates of each other.
    I just discovered that if I view the layer on its own with the mask the alignment works, but if I view it as part of the composition the mask is off.
    I could fix it by adjusting each mask frame by frame but I feel there should be a way to correct the alignment for the mask as a whole.
