Activity › Forums › Adobe After Effects › Mask in pre compose leyer
  • John Cuevas
    October 26, 2013 at 8:38 pm
    I gather English probably isn’t your first language, so you are going to need to try and explain that a little better, it doesn’t really make much sense.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Mathew Fuller
    October 26, 2013 at 8:46 pm
    I don’t really understand your question either. So I’ll give it a try.
    Maybe you need to press the “continuously rasterize” button on your pre-comp.
    It’s the button in the red box on the left side of this image.
    https://www.crookedgremlins.com/wp-content/uploads/2008/09/crandmb.png
    My Work:
    https://www.morecompletefx.com
  • Bruno Pacheco
    October 26, 2013 at 8:51 pm
    I was doing the 140 video copilot´s tutorial.In minute 11:53 Adrew Kramer used a fast blur to correct the tracking error in the precomposed layer “illumination map”: I tried using a mask to better correct the tracking error but subtract mode mask areas not covered desired … I wonder why that happens?
  • Mathew Fuller
    October 26, 2013 at 9:43 pm
    Subtract masks have to be stacked underneath add masks.
    My Work:
