Activity Forums Adobe After Effects mask based on depth-map?
  • mask based on depth-map?
    Posted by Mike Van der noordt on September 9, 2010 at 2:46 pm
    Is there a possibility to mask a layer based on a depth-map. Let me explain: I created a simple circular camera-move around a cluster of spheres in C4D, I rendered the animation out including 3D data and depth-map.
    Now I want to add some animated text-layers in front of some of the spheres(actually the camera stops at these spheres for a second, and then continues..), and let it disapear behind other spheres as soon as the camera moves away from it and other spheres obscure this text…
    I rather not animate all those masks seperately by hand, because there are about 50 spheres in my scene, and of those 50 spheres, 12 got text hovering around it..
    I hope this question is clear 🙂
    and thanx in advance!!!
    Mike
    Walter Soyka replied 16 years ago 2 Members · 1 Reply
  • Walter Soyka
    September 9, 2010 at 3:22 pm
    [Mike van der Noordt] “Is there a possibility to mask a layer based on a depth-map.”
    Here’s a suggestion: how about rendering separate depth passes, recompositing them as necessary in a precomp, applying, adjusting, and maybe animating Threshold or Levels to the depth pass precomp, and using that as an luma matte for your text?
    Walter Soyka
