Activity Forums Adobe After Effects Mask are not syncing up with new Relinked Coloured footage
  • Mask are not syncing up with new Relinked Coloured footage
    Posted by Martin Klap on November 23, 2019 at 7:26 am
    Hello all,
    This is my first post on Creative Cow, however I have received lots of help over the years from reading some of these forums. I’ve been in a blockade recently on a project that I hope the community can help me out with.
    I was asked to edit this spot and I went heavy in After Effects and did a lot of masking. After finishing the cut, I needed to send it to the Colour house, except a lot of the mask needed to be exported separately from their background plates, as there was assets between many of them. ( For example, I had cut out the main subject from the scene and put a texture flying behind him). So with the new coloured footage, I could drop it back into my AAE timeline and sync it up with the previous clips by using the same mask and settings on them.
    In theory, I could just copy and paste the mask over and it would be all good if the clips all synced up, which they did of course. Except, when I do this, none of the mask line up correctly – there always a tad off. I figure it could be something to do with the 3D camera but even then, when optioning it, nothing lines up.
    I’ve attached a video to explain and if anyone can help me out, I would appreciate it so much because I’m way overdue on this spot and getting a lot of pressure.
    I’m hoping I don’t have to re-mask everything.
    https://youtu.be/bRqx1cgEz8Q
    Greg Gesch replied 6 years, 9 months ago 2 Members · 1 Reply
  • Greg Gesch
    November 24, 2019 at 1:41 am
    Hi Martin, when you paste the masks they seem to come in with roving keyframes (the round ones not the diamond shaped ones). Strange.
