Activity Forums Avid Media Composer Marquee shapes
  • Marquee shapes
    Posted by Heidi Fentress on April 19, 2010 at 11:20 pm
    I’m using Avid Xpress Pro. I’m trying to make spinning 3-d circles in Avid. Which I have done. I just animate them spinning in the marquee editor. I want to animate them moving around in the regular editor sequence, but when I try to overlap the spinning circles with one on V1 and another directly on top in V2 the will not animate separately. How do I get the shapes when overlapped to animate differently without the marquee tool. I just want to use the effect palette. I am animating to music also BTW that is why I can’t use Marquee
    Grinner Hester replied 16 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Grinner Hester
    April 20, 2010 at 1:41 am
    a shape per layer.
    You’ll save a boatload of time by doing it in after effects.
  • Heidi Fentress
    April 20, 2010 at 1:50 am
    I cant use after effects its a school assignment. I saw my teacher do it. but for some reason my shape will combine with the other shape when I add an effect.
  • Jeff Greenberg
    April 20, 2010 at 3:46 am
    Heidi,
    There’s no way to do it the way you want. Either each shape is a separate title (and then you can use the effects palette) OR you do the animation in marquee. That part of is isn’t that hard.
    Basically, write down the length of the animation, and each ‘point’ you want something to happen.
    Set the length of the animation to match in marquee, turn on animation and move to each of the times you want animation to occur.
    Best,
    Jeff G
  • Heidi Fentress
    April 20, 2010 at 3:57 am
    yeah i tried the separate title, but when I want to resize one the other that was on a different video layer would adjust with it
  • Jeff Greenberg
    April 20, 2010 at 3:58 am
    Sounds like you nested another effect on top.
    Don’t
    Promote each title to 3d to resize it.
  • Heidi Fentress
    April 20, 2010 at 4:02 am
    omg thank you so much that was exactly what I needed. I thought I had to put Resize effect on it.
  • Grinner Hester
    April 26, 2010 at 12:48 am
    why can’t ya use AE on a school project? It’s what you’ll be using later.
