Activity Forums Apple Final Cut Pro Legacy Markers slipping out of sync!
  • Markers slipping out of sync!
    Posted by Jamie Mac on November 20, 2007 at 7:35 pm
    Am working out a way to use markers with multiclips, as i know you can’t use them directly. I was told a good way is to add markers on the source clip then multiclip them and hey presto. Seems to work but when i check the position of the markers they appear in a different place to where i marked them on the source. i.e i’m working with 2 different timecode sources, say the offset is 1min between the two cameras and it’s applying this offset to the new markers, so they appear a min later than they should, SO frustrating. Any help would be gratefully received.
    Cheers
    jamie
    Jamie Mac replied 18 years, 10 months ago 1 Member · 1 Reply
  • Jamie Mac
    November 20, 2007 at 8:05 pm
    Worked out a way. Seems that when you add markers to the source you need to make subclips of the 2 cameras starting at the same point before you make your multiclip. This way it forgets about the difference in t/c. Odd, still can’t believe you can’t subclip or add markers to multiclips.
