Activity › Forums › Adobe After Effects › Markers not sitting exactly on frame after Import – Frame snap script anyone?
  • Markers not sitting exactly on frame after Import – Frame snap script anyone?
    Posted by Ido Shor on February 10, 2022 at 1:07 pm
    Hello.
    so, as the title say, after importing markers, (either by using a .csv file or EDL) from DaVinci Resolve, some of them are not sitting exactly on a frame in the AE timeline. since I use hundreds of markers its very tedious and time consuming to manual adjust each one.
    This causes issues for me while applying certain scripts which relay on the position of the markers on the timeline.
    as anyone else encounter this problem? or maybe there is a script which does a frame-snap for the markers?
    thanks!
    Ido
    Dan Ebberts replied 3 years, 8 months ago 3 Members · 3 Replies
  • Ido Shor
    January 12, 2023 at 1:54 pm
    so… here came ChatGPT and offered this script:
    var comp = app.project.activeItem; // Get active composition
    if(comp) {
    if(comp.markerProperty.numKeys > 0) {
    var markers = comp.markerProperty; // Get markers
    var frameDuration = comp.frameDuration; // Get composition frame duration
    for (var i = 1; i <= markers.numKeys; i++) {
    var markerTime = markers.keyTime(i); // Get marker time
    var closestFrame = Math.round(markerTime / frameDuration); // Get closest frame
    markers.setCommentAtTime(markerTime, closestFrame);
    } else {
    alert(“The active composition does not have any markers.”);
    } else {
    alert(“No active composition.”);
    after effects run in to errors there, but maybe one of you wizards can take it from there 🙂
  • Walter Soyka
    January 12, 2023 at 2:25 pm
    Can you post a sample CSV/EDL that you’re using?
  • Dan Ebberts
    January 12, 2023 at 9:31 pm
    See if this works for you:
    if(comp) {
    var curMarker = markers.keyValue(i);
    var closestFrame = Math.round(markerTime / frameDuration)*frameDuration; // Get closest frame
    markers.removeKey(i);
    markers.setValueAtTime(closestFrame,curMarker);
    } else {
    alert("The active composition does not have any markers.");
    } else {
    alert("No active composition.");
