Activity Forums VEGAS Pro Markers In DVD Architect Studio
  • Markers In DVD Architect Studio
    Posted by Ray Kano on August 21, 2011 at 5:13 pm
    I’m creating a slideshow in Sony Vegas and I put two markers in it. I send it to DVD Architect Studio so that I can create two buttons on the menu; one button going to marker number 1 and one button going to marker number 2. I add one button and the destination drop down shows marker number 1 but if I try to add a second button that points to marker number 2, it’s not available on the drop down. What am I doing wrong?
    Thank you.
    Mike Kujbida replied 15 years ago 2 Members · 1 Reply
  • Mike Kujbida
    August 22, 2011 at 1:12 am
    Add the file to the main program screen twice, once for each button.
    This won’t make the DVD any bigger, it’s just a way to get DVDA to do what you want.
    In the menu on the left side of your screen, double-click the first menu item so that it shows in the DVDA timeline.
    You should see both markers in there.
    Click the second one and press ‘o’ (out point).
    Only the first section should be highlighted (the second half will be darker).
    Repeat this procedure with the second menu item only this time press ‘i’ (in point).
    This time, the second half will be highlighted and the first half dark.
    Preview it to make sure it’s what you want and then burn it.
