Activity Forums Apple Final Cut Pro Legacy Markers – How to edit/move/delete them?
  • Adam Chesbrough
    April 13, 2011 at 4:41 pm
    I have timeline markers that I want to move along when I move multiple clips at the same time.
  • Joe Kaye
    June 14, 2011 at 8:47 am
    just by the way, i was just looking to find a way to move markers more easily when i came across this thread, i have now found that if you hold cmd and click on a timeline marker you can drag it to a new position.
    i would also love options for markers to be more interactive (ie when i select all forward clips and move them that would include markers), but for the moment you can work around this by using more avid style editing techniques – ie. when you need to move everything after a certain point forward use insert slug. This will move markers (if your preferences are set that way) with the rest of the timeline, but you will often have to split clips to do this – this just means you’ll have to drag a few spliced clip segments back to where you want them afterwards….
    not perfect but not quite as time consuming as it sounds
Page 2 of 2
