Markers from Vegas not showing up in Sound Forge?
Posted by Gavin Stokes on June 17, 2005 at 9:26 pmHi all.
Bouncing back and forth between Vegas and Sound Forge works pretty well, with one glaring exception: markers. I can’t find any way to mark spots in Vegas and then have those markers show up in Sound Forge.
What’s the deal here?
Gavin
Gavin Stokes replied 21 years, 3 months ago 3 Members · 7 Replies -
Gavin Stokes
June 17, 2005 at 9:30 pmForgot to mention, I’m using the latest versions: Vegas 6 and Sound Forge 8.
Gary Kleiner
June 18, 2005 at 6:27 am -
Edward Troxel
June 18, 2005 at 12:58 pmI opened a file that was rendered with the “save markers” option turned on. It was an MPEG2 file with markers saved for creating a DVD. I opened that file in Sound Forge and the markers showed up fine. Now if you just have markers on the timeline but have not rendered, those would not show. After rendering with the “save markers” option turned on, they should appear fine when loading the new file.
Gavin Stokes
June 21, 2005 at 1:00 amThanks, but I tried that. They still don’t show up. Plus, it’s a little cumbersome to have to put everything in the trimmer and then go to Sound Forge.
Gavin Stokes
June 21, 2005 at 1:15 amThanks Edward, but there is no video to render in my project. There’s just a low-quality video track to use for timing. I set markers in Vegas (based on events in the video) and then say “open in Sound Forge.” Mysteriously, there are no markers.
I’m mystified if no one has noticed this problem. How do you set cue points for reference when you go into the audio editor?
Edward Troxel
June 21, 2005 at 1:46 pm -
Gavin Stokes
June 21, 2005 at 6:18 pmWhat would I be rendering? I just want to open the file in Sound Forge. I haven’t done anything that warrants rendering. I have to rewrite hundreds of megabytes of audio every time I want to add or move a marker? That really wouldn’t be acceptable, and it also wouldn’t make sense because the markers aren’t even stored in the audio file itself; they’re in an sfk file.
Thanks though.
