Activity Forums Apple Final Cut Pro Legacy Markers from Master Clip not making it to subclip
  • Markers from Master Clip not making it to subclip
    Posted by Matthew Cohn on April 8, 2011 at 8:02 pm
    Hello,
    I’ve been having a problem with clips from one particular tape in my project. In the master clip I want to work with, I open it up, place markers, set an In and Out and then create a subclip. The subclip is created just fine, but the markers that I set in the master clip do not are not showing up in the subclip as they should. For instance, markers that are to the left of the In that I set for a subclip show up in the subclip, but the markers I placed within the In and Out points do not get placed in the subclip. I was not having this problem with these clips yesterday, nor am I having this problem with any other clips. Does anybody know how this can be fixed or what the root problem might be?
    Matt
    Matthew Cohn replied 15 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
