Activity › Forums › Apple Final Cut Pro › Markers and Sub-Frame Audio
  • Markers and Sub-Frame Audio
    Posted by James Bayliss-smith on November 10, 2011 at 8:53 am
    Hi there, so I’m editing a music promo and I listend to the track and manually put in a load of markers on the beats.
    I then went through frame by frame and placed some more markers. When I got to the markers that I paced just by hitting M some were in between two frames.
    I’m assuming they are sub frame level? I know that if I press command right arrow I can go along at sub frame level.
    My question is why is this useful. If I can only place pictures at each frame what good id a Marker at sub-frame level when the rest of the programme works in frames?
    I’m sure the answer is obvious but I don’t know much about audio editing,
    Andy Neil replied 14 years, 10 months ago 3 Members · 4 Replies
  • Tom Wolsky
    November 10, 2011 at 9:26 am
    Audio works at the subframe level. If you open a clo in the timeline you can shift the audio to 1/80th of a frame. You can also do it in the project if the audio is broken apart. It does make lining up markers awkward though.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2011 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • James Bayliss-smith
    November 10, 2011 at 10:03 am
    Sure understood but how do you line up a clip to this audio. Are you saying you can put a marker at the halfway point between two frames then line up a clip to that?
  • Tom Wolsky
    November 10, 2011 at 10:15 am
    No, you can’t, which is why it’s awkward. You can line up other audio, but having markers at subframe level is often more a hindrance than a help.
    All the best,
    Tom
  • Andy Neil
    November 10, 2011 at 5:22 pm
    You notice the benefits of sub-frame editing when you’re dealing with frankenbiting and multiple microphone phasing. Being able to edit the audio in a sub frame environment is very nice in those circumstances.
    Andy
    https://www.timesavertutorials.com
