Activity Forums Adobe After Effects Expressions marker querying syntax question
  • marker querying syntax question
    Posted by Aaron Kent on March 2, 2013 at 8:20 pm
    Hey guys, playing around today and having a little trouble.
    This is working for me:
    (thisComp.layer(“layer1”).marker.nearestKey(time).index==1)
    this successfully tests until the CTI hits the first marker on the timeline
    what is the correct syntax if I want to instead test for the marker’s comment instead of index.
    I’ve tried things like below (and I named my marker “m1”)
    marker.nearestKey(time).comment == m1
    but I keep getting errors. I can’t find enough documentation that’s clear enough about AE expressions being able to get the comment instead of just the markers index value.
    Cheers
    AK
    Aaron Kent replied 13 years, 6 months ago 2 Members · 3 Replies
  • Dan Ebberts
    March 2, 2013 at 8:23 pm
    The marker comment is a string, so I’d try it like this (not tested):
    marker.nearestKey(time).comment == “m1”
    Dan
  • Aaron Kent
    March 2, 2013 at 8:42 pm
    Thanks Dan, I think thats got it.
    AK
  • Aaron Kent
    March 4, 2013 at 12:19 am
    Making slow progress. I need to do more beginner lessons.
    https://vimeo.com/60968609
    cheers
    AK
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
