Activity Forums Adobe Premiere Pro Marker placement issue
  • Marker placement issue
    Posted by Ryan Sarver on September 29, 2011 at 7:29 pm
    I am sure there is an easy answer to this but I haven’t the faintest idea. When I click the (*), when playing back on the timeline markers are placed without problem. When I bring a clip up into the source window and do the same thing playback stops every time I hit the (*) key on the number pad. The problem is that I am setting a number of markers for beats in a song and having it stop playback every time is quite annoying. Anyone else have experience with this problem. Any help appreciated.
    Diego Vasquez peñafiel replied 14 years, 1 month ago 3 Members · 2 Replies
  • Jon Barrie
    September 29, 2011 at 11:37 pm
    Heres the problem. Currently using a clip in the source that is actually affected directly in the sequence (clip in seq then double click to see in source monitor) and hitting marker shortcut stops playback.
    The work around here is to activate the track the clip is in, hit M key to open the matched frame of the master clip, not the instance being used in the seq. Then play and hit marker shortcut * as often as you like.
    You can then perform a replace with… to get the new marked clip to replace the instance in the edit.
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Diego Vasquez peñafiel
    August 21, 2012 at 4:37 am
    Try reseting your workspace
