Activity Forums Zaxwerks Margin cutting off
  • Margin cutting off
    Posted by Kevin Mote on February 24, 2010 at 2:49 pm
    Very new to ProAnimator. I’m sure this is an easy fix, but I haven’t been able to figure it out as yet. I’ve created a simple animation in a 720p Motion project. As the animated logo exits the frame, the image shows that it has a limited right edge as if the margin needs to be expanded. I’ve increased the margin in Motion, but that does nothing to help the problem. Please click the link to see this:
    https://homepage.mac.com/kevinmote/Enclose/Picture_3.png
    How can this be fixed?
    Edward Wu replied 16 years, 6 months ago 2 Members · 1 Reply
  • Edward Wu
    February 24, 2010 at 6:18 pm
    Hi Kevin,
    I’m not sure how you are setting up the project from your screen shot, but from the looks of it, it might be because you are not applying ProAnimator FX to a Color Solid that is project size. To avoid clipping issues, first create a Color Solid that is project size. Then, apply ProAnimator FX to the Solid. This way, whatever you create in ProAnimator FX should fit exactly into your project window.
    Hope this helps.
    Best,
    Edward
