Activity Forums Adobe Premiere Pro Mapped keyboard shortcuts sometimes do not work on timeline but works in source monitor.
  • Mapped keyboard shortcuts sometimes do not work on timeline but works in source monitor.
    Posted by Adam Berch on February 2, 2018 at 4:35 pm
    HI,
    I am using Premiere Pro CC 2018
    I have mapped out my keyboard. I assigned the Left & Right Arrows to move up or down one frame at a time. I have also mapped keys so I can go to next cut and previous cut.
    Sometimes When I press the arrows to move one frame back or forward on the timeline, it does not work. Yet, when I try to do the same thing on a clip in the source monitor with the same keys, it works fine.
    Why does this happen?
    The only way I can get it to work on the timeline again, is to Quit Premiere and re-open it again. Then after a while it does not work again.
    How can I fix it?
    Thanks in advance
    Eric Merklein replied 8 years, 7 months ago 3 Members · 2 Replies
  • Tero Ahlfors
    February 2, 2018 at 4:51 pm
    Left/right arrows are by default bound to the global application commands to move one frame forward/back and the up/down arrows will go to prev/next edits. If you’ve changed them to work in some specific window then they will only work when that window is active. I have no idea why one would want this though.
  • Eric Merklein
    February 2, 2018 at 6:16 pm
    I’ve re-programmed a lot of my key strokes as well, but I don’t have any problems. You may want to trash your prefs.
    Eric
