Activity Forums Maxon Cinema 4D Map Image to Sky
  • Map Image to Sky
    Posted by Andy Baumgartner on July 15, 2009 at 8:44 pm
    Hi. I would like to map an image to part of a sky object in Cinema 4D so I can pan from the bottom to top in 3d space. I’m sure this is a common procedure but I have no idea what it’s called or what to search for tutorial wise. Anyone have any ideas or tutorial links? Thanks.
    Andy Baumgartner replied 17 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    July 15, 2009 at 10:51 pm
    just apply your image (Color or luminance channel probably) in a material to the sky then set the MAterial tags Mapping/Tiling/Offset etc to get it where you want.
  • Andy Baumgartner
    July 15, 2009 at 11:21 pm
    Thanks Brian!
