Activity › Forums › Adobe After Effects › Manually tracked Mocha data not importing into After Effects?
  • Manually tracked Mocha data not importing into After Effects?
    Posted by Austin Witherspoon on October 4, 2016 at 5:32 am
    So I tracked this TV in the background, and once the actors hand and cellphone went in front of it, I had to go frame by frame and track it.
    When I export tracking data though, it only exports the stuff that was actually tracked by mocha, none of my adjustments that I manually did when the hand and phone pass in front of the TV.
    How do I get my track loaded into After Effects? In mocha it plays back fine with the outline following where the TV is.
    Roei Tzoref replied 9 years, 11 months ago 2 Members · 1 Reply
  • Roei Tzoref
    October 7, 2016 at 9:53 pm
    the bar should be purple where you have keyframes . for some reason the manual adjustment you made were not registered. make sure you set the motion panel to manual track and the bar should turn purple on every adjustment:
    more information here:
    https://vimeo.com/144089631
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
