Activity Forums DaVinci Resolve Manually Setting White Balance with v12
  • Manually Setting White Balance with v12
    Posted by Bill Ravens on August 2, 2015 at 3:57 pm
    With the revised CURVES window, it’s very difficult to manually set the White Balance. V11 allowed zooming on the window, which also had a graticule. This current version is almost impossible.
    Is there also some way to visualize the RGB curve values, and adjust them, for a white point or grey point?
    Marc Wielage replied 11 years, 1 month ago 2 Members · 1 Reply
  • Marc Wielage
    August 11, 2015 at 1:59 am
    I think you can still white balance with the primaries, but I have to admit, I miss the Big Curve Window mode from v11. I suspect a combination of desat curves and primaries will get you where you need to go.
