Activity Forums Event Videographers manual white balance?
  • Andrei F.
    August 27, 2005 at 2:38 pm
    I agree with Velma. While shooting in big house I may use 3 or 4 different settings (I have 8 manual ones and 4 presets, but this is too much to keep in memory). You can evaluate approximately, what kind of lighting is prevaling in each room or in each spot, then use approproiate filter and the setting to that filter. Another trick: if I use 2 different settings for the same filter, my setting #1 is always warmer than the setting #2.
    It really depends on camera you are using, but you can build a pattern you keep working with and stick to 3 settings at each place.
    Andrei, https://www.faqvideo.com
Page 2 of 2
