Activity › Forums › Adobe After Effects › manual preview scrub audio start
  • manual preview scrub audio start
    Posted by Andy Engelkemier on April 8, 2016 at 2:51 pm
    When you cold control (on PC) while holding the current time indicator without moving it plays a little loop of the audio with a few frames on either side of it.
    I’m using this to find the exact start of one instrument among others. I have the waveform open, and you can see large beats. But say I want to see a single piano note with a bunch of strings sustaining? You can’t see that clearly in the waveform. The loop goes on either side of your cursor. I want to find the “hit” so I’d rather that preview be only on the right.
    Is that possible? I thought you could change the amount of time somewhere. I’m hoping you can also change that.
    This is the only mention I could find of it. I had to use Google to search today also because I’m getting an error 413 for the Adobe search pages. :/
    https://helpx.adobe.com/after-effects/using/previewing.html#manuallypreviewscrubvideoandaudio
    Andy Engelkemier replied 10 years, 5 months ago 55,188 Members · 1 Reply
  • Andy Engelkemier
    April 8, 2016 at 5:08 pm
    In previous version of AfterEffects all I had to do was listen to the entire track and tap along with the star key. I have pretty good timing, so that was almost always spot on. But since somewhere around CS6 through CC, there’s a little bit of lag every time you add a marker.
    But that’s exactly how it works in Audition as well. So I just did it there, saved over the file, right clicked on a marker on the audio file and chose “replace all markers from source”
    I thought it might choke a bit because I added 500+ markers, but it did fine.
    your solid idea isn’t so bad for some of the ones that Really need to hit perfectly. But if I had to do that a ton I would hope for a faster workflow.
    I wasn’t looking to automate it. I was just looking to see if I could change a setting that’s already there. In that click and hold preview, I want it to start from that point instead of play around that point.
