Activity Forums Apple Motion Manipulating Media in Drop Zones
  • Manipulating Media in Drop Zones
    Posted by Jose Minay on July 7, 2010 at 4:16 pm
    I am using a Motion project with drop zones and I need to be able to manipulate the picture/footage within the drop zone. I can’t select the media to move it around or resize it. I read several threads that say you can’t do it within motion and need to resize it outside of motion to achieve the desired area of the picture I want to appear.
    The reason why I am posting this is because I have been able to randomly select the media before. It has been a while since this has happened to me so I thought i was just making it up in my head. I just opened a project with drop zones in it and the first drop zone allowed me to select the picture within the drop zone and I was able to move it an re-size it to my liking. When I moved on to the next drop zone, i was unable to select it like I did the first. Why is this?
    If I wasn’t able to do this in the first one then I would just resort to re-sizing it in Photoshop like I always have. But the fact that I can do it randomly with some, makes me want to look into it more. I would really like to get to the bottom of this because it is SO much easier to be able to manipulate the picture/footage within the drop zone.
    I would appreciate if anyone could help me with this. THANKS!
    Jose M.
    Federico Betta replied 14 years, 9 months ago 10 Members · 22 Replies
  • 22 Replies
  • Noah Kadner
    July 7, 2010 at 5:39 pm
    yeah I find them to be somewhat inflexible. If you’re using them a lot I’d suggest simply rebuilding the whole template and doing it that way.
    Noah
    Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
    Learn DSLR Cinematography.
  • John Doggett-williams
    July 8, 2010 at 12:30 am
    Wish I had the answer too. I have a similiar problem with a soundbite (10 seconds long) I want to put in a drop zone – the interview (media) is 7 minutes long. Is there a simple way to trim it in Motion or do I really have to export it from FCP?
    Cheers,
    John doggett-williams
  • Mark Spencer
    July 8, 2010 at 3:28 am
    You can always slip your media in Motion to the appropriate point by option-dragging on it in the mini-Timeline (it needs to be trimmed first just like in FCP).
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
    July 8, 2010 at 3:52 am
    thanks Mark, I’m still getting the hang of it. Option dragging still isn’t as efficient as exporting from FCP is it? For example my media is 7 minutes long and contains 3 10seconds soundbites I need, that’s a lot of option dragging to do each time (but I’ll survive). Is it better to export the bits I need directly from FCP and once in Motion copy and past into the template I want to use?
  • Mark Spencer
    July 8, 2010 at 4:11 am
    Yes I would just export from FCP the bits you need.
    Mark Spencer
    July 8, 2010 at 4:20 am
    Great that clears that one up. One last really basic question, is there a shortcut to toggle between projects?
  • Mark Spencer
    July 8, 2010 at 5:23 am
    Sure, Command-` (The “grave” key) will toggle amongst all your open windows, including all open projects.
    Mark Spencer
    July 8, 2010 at 5:37 am
    Great, thanks
  • Andy Neil
    July 9, 2010 at 5:36 pm
    I discovered a method that allows you resize images inside a drop zone. Best of all, it works in 3D projects as well. I’m actually going to create a mini tutorial on my You Tube page that shows off the technique if you’re still interested.
    Andy
    https://www.timesavertutorials.com
    July 10, 2010 at 3:59 am
    Yes, definately, I’ll keep an eye on your site.
Page 1 of 3
