Activity Forums Canon Cameras Manfrotto LANC and XH-A1s
  • Manfrotto LANC and XH-A1s
    Posted by Brian Johnson on July 5, 2010 at 10:47 pm
    I recently purchased the Manfrotto 523PROi LANC controller for use with my XH-A1s camera. I’ve found that the zoom response is a bit laggy. I get a much faster response from using the zoom toggle on the camera. Does anyone know if this might be a setting I can change somehow either on the controller or the camera itself?
    Christian Schnabel replied 16 years, 1 month ago 3 Members · 3 Replies
  • Brian Louis
    July 6, 2010 at 10:31 am
    Hold the zoom speed button until the LED fl ashes and use the wheel to set your speed
  • Brian Johnson
    July 6, 2010 at 9:17 pm
    The issue I’m noticing isn’t with the speed of the zoom, it’s the speed in which the zoom kicks in once I push the controls.
  • Christian Schnabel
    July 23, 2010 at 4:35 pm
    Hi Brian,
    is the AF button of Manfrotto 523 Pro working with the XH-A1s? Mine is not but it is working on XM2 camera.
    Is there any setting on the XH-A1s to activate it?
