Activity Forums Apple Final Cut Pro Legacy Making Viewer Larager
  • Making Viewer Larager
    Posted by Bob Tanner on May 14, 2009 at 7:51 pm
    I’m trying to make the viewer screen larger to view the full size of the filter’s window, below the Coloristia Effect and I can’t see all the dials…
    Zevie
    Bob Tanner replied 17 years, 4 months ago 3 Members · 4 Replies
  • Bob Tanner
    May 14, 2009 at 8:08 pm
    Thanks for that, I feel real smart now…
  • Shane Ross
    May 14, 2009 at 8:10 pm
    Isn’t that a pain in the patoot? Make the VIEWER larger. Like use the TWO UP Arrangement, then see if you can drag that box larger. That is what works for me.
    Shane
  • Michael Sacci
    May 14, 2009 at 8:13 pm
    There should be Column headers Name | Parameter | Nav above the Video Filters, if you click and hold on the right side line you can drag it to the right and it makes the column wider.
  • Bob Tanner
    May 14, 2009 at 8:53 pm
    Last question, once I dragged Colorista Filter to the right, It took up a lot of room, blocking the canvas, is there anyway to keep the viewer the same size and make the filter windows smaller?
