Activity Forums AJA Video Systems Making Switch from Cinewave (HD) to AJA KONA 2
  • Making Switch from Cinewave (HD) to AJA KONA 2
    Posted by Dale Launer on August 15, 2005 at 9:08 am
    I have a current project (HD Cinewave/Targe 1080p 23.98) project which I’d like to switch over to AJA if possible. I can export to Apple 8 bit uncompressed, but…it looks crappy – milky, the colors look wrong (kinda like animation).
    What am I doing wrong? I believe this is the right codec for AJA .I’m playing the Apple uncompressed 8 bit file through my Cinewave rig – would it look different – better – if I played it back through the AJA rig?
    Walter Biscardi replied 21 years ago 3 Members · 3 Replies
  • Christopher Tay
    August 15, 2005 at 9:55 am
    The Kona2 is capable of playing back your CinewaveHD clips so no transfer is needed.
    -chrispy
  • Dale Launer
    August 16, 2005 at 8:12 am
    What if I want to bring in more material? Will it (Kona 2) capture the Cinewave codec?
    And what about render files? Will they be in Cinewave/Targa codec? Or Apple Uncompressed? (I was under the impression the Kona 2 works with Apple’s uncompressed codec).
    Dale
  • Walter Biscardi
    August 16, 2005 at 11:27 am
    [Dale Launer] “What if I want to bring in more material? Will it (Kona 2) capture the Cinewave codec?”
    As far as I know, the answer is no, it will not capture in the CineWave codec. You need a CineWave board to do that.
    You would simply capture in whatever codec matches your original footage. I.e. if you captured 8bit in CineWave, then use the AJA 8bit NTSC (or PAL) preset.
    [Dale Launer] “And what about render files? Will they be in Cinewave/Targa codec? Or Apple Uncompressed? (I was under the impression the Kona 2 works with Apple’s uncompressed codec).”
    They will be the same as your Sequence setting. Again, you will not be working with the CineWave codecs any longer if you don’t have the CineWave board.
    I made the switch almost a year ago now and haven’t looked back. In fact we added a second K2 system to the shop.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
