Activity › Forums › Adobe Premiere Pro › making subclip from sequence
Posted by Joe Mole on June 19, 2009 at 2:55 amIs there a way to make a subclip from a sequence? I created a sequence to do multi camera editing but now I’d like to make subclips that would be multicamera editable.
Ht Davis replied 7 years, 4 months ago 9 Members · 18 Replies -
Eric Jurgenson
June 19, 2009 at 2:29 pmCan’t you just copy and paste a portion of your sequence into a new sequence?
Joe Mole
June 19, 2009 at 6:41 pmYes. Though that is not helpful for my purposes. I want to label and organize clips as I am creating a documentary and the flow of the video is grouped according to ideas not the timeline of video. Labeling and organizing is easier done when I have subclips rather than a million copy and pasted clips in a timeline.
Shane Icenhour
July 17, 2009 at 10:43 amHere a tutorial link if it helps. It seems a little similar to how Avid handles them.
https://www.layersmagazine.com/using-subclips-in-premiere-pro.html
H. Paul moon
May 22, 2011 at 10:41 pmThat actually doesn’t help at all. It merely explains the basics of making subclips from clips, not subclips from sequences.
My compromise has been to create nested sequences and rename each individually as if they were subclips.
Joe Mole
February 11, 2013 at 10:10 pmIronically I haven’t found a solution to this yet. Thanks for the workaround, I’ll see how it works out for me.
Anthony Bernard
May 21, 2013 at 8:24 pmIm currently in the same boat. I have 10 days worth of interviews for this doc that I need to multi-cam then sub-clip, but apparently there is still no way to do this short of duplicating the multi-cam sequence and trimming them individually into each sub clip? Not even in CS 6?
Loraine Clarke
August 14, 2013 at 4:24 pmDid either of you find a way to work around this? I have the same problem and would greatly appreciate any advice you can offer.
Loraine Clarke
August 14, 2013 at 7:11 pmah I see. Thanks. Like you said a compromise but better than nothing. Thanks
