Activity Forums VEGAS Pro Making Stock Clips Work
  • Making Stock Clips Work
    Posted by Ken Vaughn on January 25, 2012 at 2:34 am
    So I’m trying to use these stock clips and I’ve fiddled with the file trying to keep it from stuttering on playback but no luck.
    The project is;
    • 720 x 480
    • 29.970FPS
    • Square Pixel
    The clip is;
    • 1920 x 1080
    • 30FPS
    • Square
    As I mentioned I’ve changed settings etc. but no joy. I’m sure it’s something simple.
    Thanks in advance,
    Ken
    Another unscheduled off-world activation…
    Graham Bernard replied 14 years, 8 months ago 2 Members · 5 Replies
  • Graham Bernard
    January 25, 2012 at 4:46 am
    Ken?
    1] What version of Vegas?
    2] First off try using Match Media icon in Project settings.
    3] Stock footage? From where? What CODEC?
    You’ve got some variables that need to be ascertained prior to setting project settings.
    Grazie
    Grazie
  • Ken Vaughn
    January 25, 2012 at 4:53 am
    Grazie,
    Thanks for the reply. To answer;
    I will try the “Match Media” setting now.
    Thanks again,
    Ken
    ADD: No joy on the “Match Media” setting. And it’s a .mov file, forgot that first time around.
  • Graham Bernard
    January 25, 2012 at 5:09 am
    No worries.
    Preview may be rough. I beieve you need to have QT installed on the PC. Try rendering out a small bit.
    OK, mixed media projects are tough on processing to Preview. I’d contemplate converting/rendering-out to your Project settings PRIOR to a full edit.
    Cheers
    Grazie
  • Ken Vaughn
    January 25, 2012 at 5:15 am
    I have another .mov clip from a different source (Footage Firm) in the project and it plays fine, smooth all the way. I’ve never used Media Match before and I checked the help file so I assume you must select a known file without issues and match it. This is what I did with the aforementioned .mov that works and I saw no change. I’m going to render now and see if there is a difference.
    Ken
    Well I learned a lesson here, not about Vegas but about “assumptions”. I assumed that because the other .mov clip played smoothly in the project, the one in question should also….WRONG!
    After rendering the file plays as smoothly as I could ask for.
    Thanks for the input and the lesson Grazie.
    Ken
  • Graham Bernard
    January 25, 2012 at 7:33 am
    Good oh.
    Cheers
    G
