Activity › Forums › Apple Final Cut Pro Legacy › Making source time code visible
Posted by Leonard Frankford on November 19, 2010 at 2:45 pmI need to make a time code window dub for a client. In the old days of tape this was easy. How do I make the source time code visible on the timeline for output? Thanks.
Leonard F.
Leonard Frankford replied 15 years, 10 months ago 2 Members · 4 Replies -
Shane Ross
November 19, 2010 at 3:20 pmSOURCE…of the clips? Or the timecode from the timeline?
Here’s a tutorial:
https://library.creativecow.net/ross_shane/visible-timecode/1
Shane
Read my blog, Little Frog in High Def -
Leonard Frankford
November 19, 2010 at 8:50 pmThe timecode of the source clips. Is there a way to drop them on the timeline and see the source clips timecode in the sequence window as the clips are playing?
Leonard F.
Shane Ross
November 19, 2010 at 8:54 pm[Leonard Frankford] ” Is there a way to drop them on the timeline and see the source clips timecode in the sequence window as the clips are playing?”
Yes. Add the TIMECODE VIEWER filter on each clip (just highlight them all, then drag the filter to the clips, it will go to every one), and render the clips.
Shane
