Activity › Forums › Adobe Illustrator › making shape look “indented” in sphere
  • making shape look “indented” in sphere
    Posted by David Morin on March 20, 2012 at 2:29 am
    I have a sphere and i want to create a custom shape on it that appears to be in the sphere. How can i achieve this? As you can see i have a basic setup but the outlines are showing in this.. I think im close but need a bit of guidance. Thank you
    “how to make this better”
    Vincent Rosati replied 14 years, 6 months ago 2 Members · 1 Reply
  • Vincent Rosati
    March 23, 2012 at 11:12 pm
    Sounds like you just want to remove the black lines – Just select all of the objects, then near the bottom of the Tools palette you’ll see the Fill & Stroke controls. Click the small double-arrow so that the Stroke is in the front, then click the None button below it (the small square with the red line).
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
