Activity › Forums › Adobe Illustrator › Making radial gradient from color to transparency
  • Vincent Rosati
    June 15, 2009 at 10:28 pm
    First, I’d make swatches for all of the colors.
    Second, create a gradient swatch that holds the dark and light colors.
    Here’s tutorial on how to make a radial pattern…
    https://library.creativecow.net/articles/rosati_vincent/radial_patterns.php
    Once you determine how many divisions you want in the radial pattern, you would create your main ‘wedge’ or spoke, apply the gradient to it, than use the technique in the tutorial to complete the pattern.
    Vince
