Activity Forums Adobe After Effects Making Presets – After Effects error: internal verification failure, sorry! {unexpected match name in group} (29 :: 0)
  • Making Presets – After Effects error: internal verification failure, sorry! {unexpected match name in group} (29 :: 0)
    Posted by Bijan Sam on February 7, 2015 at 1:00 am
    I am attempting at making a preset for myself, because I want to speed up the time it takes to make and add effects to layers.
    I began by using an online generator to generate my preset shell (the outline of the preset). I then took the code it gave me, and
    pasted it into my PresetEffects.xml (C:\Program Files\Adobe\After Effects CC 2014\Support Files\PresetEffects.xml) and when I went
    into After effects CC, I opened up the script editor (File>Scripts>Open Script Editor), then I pasted my import java code:
    app.project.activeItem.layer(1).effect.addProperty("Audio_Waveform_Wheel");
    When I press the “Run” button, something happens, then on my after effects a pop up message comes up saying:
    When I press OK, it just opens up again. My software also looks a little messed up. What is going on?
    How do I fix this issue?
    Michael Szalapski replied 11 years, 6 months ago 3 Members · 3 Replies
  • Todd Kopriva
    February 7, 2015 at 3:02 am
    Install the most recent update. You are using an out-of-date version of After Effects.
    After Effects product manager and curmudgeon
    After Effects team blog
  • Bijan Sam
    February 7, 2015 at 4:33 am
    Hey! I was wondering if I am able to do it with any version of after effects? Or do I need the latest to make presets?
    For example, can I use Adobe After Effects CS5.5 to make presets? Or will it crash as well?
  • Michael Szalapski
    February 10, 2015 at 6:23 pm
    You should be able to make presets in other versions. Todd was just saying that the version you were using needed to be updated to fix bugs.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
