Activity Forums Adobe After Effects Expressions making opacity binary (on or off) with expression
  • making opacity binary (on or off) with expression
    Posted by Adam Browne on August 29, 2012 at 8:29 pm
    I’m trying to make an effect controlled by music, and I need to make a layer’s opacity controlled by the Audio Amplitude keyframes I converted from the audio. I think I’m 80% there with this expression on the opacity of the layer:
    transform.opacity=(thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”))
    That’s varying the opacity, but what I need is for the layer’s opacity to be binary, either 0% or 100% depending on the “audio amplitude”. In other words, I want to be able to say, “if the amplitude is greater than X, be ON, if not, be OFF” Does that make sense? Any ideas?
    transform.opacity=(thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider"))
    Adam Browne replied 14 years ago 2 Members · 2 Replies
  • Anna Blume
    August 30, 2012 at 8:54 am
    Hi Adam,
    I’m also a beginner, but try the expression attached. If you connect the variable maxVal with an additional slider you can also change this value over time.
    maxVal = 80;
    if (thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider") >= maxVal) {
    100}
    else {
    0}
  • Adam Browne
    August 30, 2012 at 5:38 pm
    That did it! Thanks! This is my first foray into expressions… so much more to learn.
