Activity › Forums › Maxon Cinema 4D › Making objects and floor hard
  • Making objects and floor hard
    Posted by Jatin Makwana on July 12, 2008 at 9:46 pm
    hi all,
    i want to make a few objects hard (so they can’t go through each other). All the objects are normally animated (Not particles).
    Also i require the floor to be un-penetrate able
    is their an easy way to do this?
    thanks in advance.
    Jat
    Randy Johnson replied 18 years, 2 months ago 3 Members · 2 Replies
  • Steven Jenkins
    July 13, 2008 at 6:58 pm
    What you’re describing requires physics simulation. To do this you can use the dynamics module, or buy a plugin like Phytools. Otherwise you can use the dynamics simulation capabilities of Thinking Particles, and/or Xpresso, with or without TP, depending on how good you are with Xpresso. Or, you can keyframe manually. How complex things are depends on how many objects are in your scene.
  • Randy Johnson
    July 17, 2008 at 8:22 pm
    reacting with a floor is not simple.
    But to prevent things from going through it i tend to use constraint tags…but as Steven stated above there is no easy way to get “nice” dynamics.
    randy
