Activity Forums VEGAS Pro Making master dvd from HD video
  • Making master dvd from HD video
    Posted by David Vanderveken on October 13, 2008 at 8:17 pm
    Hello,
    I’m not shure if I’m doing this right. I recorded a videoclip with the HVX-201 cameravon P2 cards. Recording format: DVCPRO HD 720P/25PN.
    I used Raylight to make the Panasonic MFX files to avi files to import in Sony Vegas Pro 8. The clips are 1280 x 720 x 32, 25fps
    These 39 clips were around 10 GB each which is way too big to work with, even with a “heavy” computer. So I converted them using Cineform Neo HDV and that worked great but I propably lost some quality here,no?.
    Now I need to make:
    – a master dvd for the client for viewing on a normal tv
    – a master dvd that will be used to make a digi beta from it.
    – a Blu-ray disc for viewing on a HD television screen
    I’m confused about which rendering option I should use for these. I I also think it would be better to render video and audio seperatly, or am I wrong here?
    Can anyone be of assistance please?
    Thank you.
    David Vanderveken replied 17 years, 11 months ago 2 Members · 2 Replies
  • Steve Rhoden
    October 13, 2008 at 10:50 pm
    Don’t worry the reduction in image quality by converting to
    cineform intermediate is minimal.
    That’s also correct…Render your video and audio separately:
    Choose a “MPEG2-DVD Video stream template” or your video:
    And for your audio “48,000:16Bit:PCM” Template or the ac3
    format.
    So give them the same name when rendering, so that when you
    import into Architect both audio and video will be linked.
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
    sample bits at
    http://www.youtube.com/hentys
  • David Vanderveken
    October 14, 2008 at 2:15 pm
    And again Steve, Thank you for your help !!
    David
