Activity › Forums › Adobe After Effects › Making everything just a bit longer?
  • Making everything just a bit longer?
    Posted by Tim Bond on March 30, 2007 at 5:34 pm
    Hi all,
    I have a montage of text and stills coming in / fading in & out of the screen but its all a bit quick. Is there a way i can globally increase the time of all the layers? Or do i have do do it one at a time and shift everything else along as i go?
    Tim B
    Tim Bond replied 19 years, 6 months ago 3 Members · 3 Replies
  • Steve Roberts
    March 30, 2007 at 5:37 pm
    You can select all the keyframes, then hold down alt/option and drag the last one to the right.
    Or you can drag the comp into another one, then change its speed/duration within that comp.
  • Danny Princz
    March 30, 2007 at 5:39 pm
    quick and dirty…
    place said comp in to a new, longer comp.
    enable time remapping for the orig comp layer and stretch the piece to the new length you desire.
    as long as there is no moving footage, it should look perfect
  • Tim Bond
    March 30, 2007 at 5:54 pm
    Thank you both very much
