Activity › Forums › Apple Final Cut Pro Legacy › Making dark video footage light
Posted by K-1 on November 15, 2005 at 6:31 pmHey Community
How do I make dark(poorly lit) video footage light? Can someone please suggest a workflow.
K-1
Gary Hughes replied 20 years, 10 months ago 3 Members · 2 Replies -
Thaxter Clavemarlton
November 15, 2005 at 7:16 pmVideo Filter > Color Corrector 3-Way
Adjust the “Whites” and “Mids” UP a bit.
Then adjust the “Blacks” DOWN a bit.
You may need to adjust the “Sat” (Saturation) after ypu decide on the levelsThis will take a lot of time as any ONE adjustment will interact with the OTHERS.
Once you get the filter to look the way you want it, you can save it as a “Favorite” and/or “drag” this filter to the Browser so you can use it again as needed.
Gary Hughes
November 16, 2005 at 7:48 amDepending on your actual footage, you may be able to use the shadow/highlight plugin that’s free from Lyric. https://www.lyric.com/index.htm I haven’t tried it yet, but it’s supposed to increase the brightness in the shadows without making it look washed out. I’ve used similar plugins for Photoshop before.
Gary
