Activity › Forums › Maxon Cinema 4D › Making Cuts w/ Other Primitive Objects
  • Making Cuts w/ Other Primitive Objects
    Posted by Mike Ebert on April 26, 2010 at 4:26 am
    I was wondering how is the best way to make a cut into a polygon “mesh” using another object…say you have a hypernurbs polygon object that I have modeled but I would like to cut and possibly join together with a cylinder at a certain junction.
    This is the xray model of the hypernurbs object and the polygon primitive
    This is the model of the hypernurbs object and the polygon primitive. I dont necessarily want the cylinder to stick out at all but that is the shape that i would like to cut into the hypernurbs object and join the geometry so that I dont create a void or a hole in the surface of the hypernurbs object.
    Thanks in advance.
    Randy Johnson replied 16 years, 5 months ago 2 Members · 1 Reply
