making custom sequence preset for wired format.
Hello all,
I’ve been given footage that has a special format.
When I check the Item properties in FCP it tells me:
25fps
frame size
720×404
data rate 617.1k/secWhen I check the properties with Compressor it tells me
Type: MPEG-2 Program stream
Encoded bounds: 720×480
Pixel aspect ration: NTSC CCIR 601/DV (16:9)
Frame rate 29.97If I open it in Quicktime it tells me the frame size is 720×404.
Because of lack of time I had to edit it quickly so I put HD (1440×1080) compressor HDV 1080i50
Sequence Preset in FCP as I know HDV uses MPEG-2 and with that aspect ratio the image stayed more or less the same.
Know I want to know what is to be done to actually have the RIGHT sequence preset in oder to not change the aspect ration and not lose quality when I export QuickTime (current settings of the).
Is it secure to render the sequence in Apple Pro Res 422 and export that ?motion pictures + storytelling = ?
-> FILMMAKING !
