Activity Forums Adobe Audition Making crowds or conversations unintelligible
  • Making crowds or conversations unintelligible
    Posted by Jim Bachalo on January 24, 2012 at 2:09 pm
    Hi
    I shooting a small crowd scene of anywhere from 10-20 people. I need to somehow use the natural recorded audio and ambience but make most of the recorded voices somehow unintelligible, sort of like walla, but it still has to sound natural.
    Does this make any sense?
    Is there any way to do this?
    Local is the new global
    Angelo Lorenzo replied 14 years, 7 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    January 25, 2012 at 5:46 pm
    Without listening to your audio or knowing how exactly it was recorded, I would try the following:
    1. Sweep a wide Q filter around 500Hz-2kHz and give it a cut to see what muffles the presence of the crowd.
    2. Once you have that in place, try a slight boost at approximately 3kHz to get some high end percussive back into the sound.
    You could also try some multiband compression or, if this was recorded with stereo mics for ambient, try some mid-side compression and eq in the center of the ambient and let the far stereo kind of come in clearly.
