Activity Forums Adobe After Effects Expressions making copy of a parent follow the parent’s position but in opposite x axis
  • making copy of a parent follow the parent’s position but in opposite x axis
    Posted by Yamir Bhatt on June 9, 2009 at 2:44 pm
    I am tring to create 2 objects starting to move from the sape position. but i only want to key frame one object. hopping the other object will follow its position but in opposite x axis. what is the siplest way to do this?
    Yamir Bhatt replied 17 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 9, 2009 at 3:17 pm
    A position expression like this should do it:
    L = thisComp.layer(“parent”);
    p0 = L.transform.position.valueAtTime(0);
    p1 = L.transform.position;
    [2*p0[0]-p1[0],p1[1]]
    Dan
  • Yamir Bhatt
    June 9, 2009 at 3:28 pm
    thanks that worked perfect. thanks
