Activity Forums Apple Final Cut Pro Legacy making an uncompressed file
  • making an uncompressed file
    Posted by Ben Oliver on April 9, 2007 at 7:27 pm
    hey guys,
    i shot a music video using the p2 cards. i know need to render out an 8bit compressed file, but it’s getting wonky.
    my timeline is
    dvcproHD 720p60 960×720 48khz audio
    what do you all recommend?
    Russell Lasson replied 19 years, 5 months ago 4 Members · 4 Replies
  • 13 Create COW Profile Image
    13
    April 9, 2007 at 7:30 pm
    what format was your camera set to record at on to the P2 cards
  • Ben Oliver
    April 9, 2007 at 7:32 pm
    720pn
  • Jeremy Garchow
    April 9, 2007 at 7:49 pm
    How are you rendering it out? And do you mean 8 bit uncompressed HD, or SD?
  • Russell Lasson
    April 9, 2007 at 8:10 pm
    Did you go to:
    File-Export-QuickTime Movie
    Settings: Custom
    Then –
    Frame Size: HDTV 720p (16:9)
    Pixel Aspect Ratio: Square
    Anamorphic 16:9: Unchecked
    Editing Time Base: 23:98
    Compressor: Uncompressed 8-bit 4:2:2
    Then –
    Select the video processing tab and select “Render all YVU material in high-precision YUV” and change motion filtering quailty to best.
    Then – Go for it.
    Did that look better?
    Note: It’s probably better if you delete your render files first.
    -Russ
