Activity › Forums › Compression Techniques › making an M2TS for festival projection
  • making an M2TS for festival projection
    Posted by Stephen Vilash on May 3, 2013 at 10:58 am
    we need to provide a festival venue with an .m2ts file for digital projection.
    the workflow for making a Bluray is something we’ve done in the past.
    we bring in the Pro Res files to Compressor, make an elementary stream .m2v + AC3 sound, bring that together to a .ts file in MPEG Streamclip and its ready for burning with Toast.
    however, i am confused about the workflow for an .m2ts file with these requirements:
    Used video codec should be 100% compatible with the H264 codec and specifications used for blu ray disc.
    • H264 Format
    • Main Profile, level 4.1
    • Maximum Video bitrate of 40 Mbit/s
    • Maximum AV bitrate (combined audio and visual bitrate) of 48 Mbits
    • Can be VBR or CBR bitrate
    Used audio codec should be 100% compatible with the Dolby codec or PCM codec and specifications used for blu ray disc.
    • Linear PCM (LPCM) up to 8 channels (7.1), uncompressed audio
    • Maximum bitrate of 27Mbit/s
    • However: maximum AV bitrate (combined audio and visual bitrate) of 48 Mbits
    I am assuming i should make a Transport Stream of the Pro Res video, but what settings are needed in Compressor to have h264? also, what’s the best compressor setting for LPCM sound file?
    Once i have these, should I use MPEG Stremclip again to bring them to one file?
    i only see the possibility to get files with a .ts extension, not an .m2ts
    any professional help would be much appreciated!
    Stephen Vilash replied 13 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
